Results 1 to 5 of 5
Thread: MAZDA 3
    Oct 2016
    Default MAZDA 3
    HI PLZ
    NEED HELP
    MAZDA 3 YEAR 2014 BL10Z2 D'ONT START I HAVE FAULT U0155 LOST COMMUNICATION WITH THE CONTROL
    MODULE WITH THE PANAL CLUSTER INSTRUMENT
    I JOIN FILE EEPROM FOR ECU AND CLUSTER
    THANK YOU
    Nov 2015
    where is this fault code? in ecu? cluster tool responds to diagnosis? use mazda ids and try a pairing. if the cluster does not respond to the diagnosis check the can line,
  3. The Following User Says Thank You to cristi5075 For This Useful Post:
    krimou (7th December, 2020)
    Oct 2016
    CLUSTER does not respond to the diagnosis
    Oct 2016
    TO ALL IM NOT ACTIVE MEMBER I KNOW YOU DON'T HELP ME
    Nov 2015
    Quote Originally Posted by krimou View Post
    put others and write eepr from the originals
