Results 1 to 12 of 12
    Dec 2020
    Default Need ECU file for E46 320d 150hp 6 gear
    I need ecu file for my e46 150ps 6 gear, cause i'm driving on 5 gear ecu file and 5th gear jerks... EDC16, 12/2003.
    Apr 2011
    You have better chances to get file if you post more info about ECU, is it original to the car, HW/SW numbers, what has been changed etc..
    Dec 2020
    ECU is original, but someone write file from 5gears... where can i find hw/sw numbers?
    Mar 2017
    Hi, do you have a picture of your original ecu sticker?
    Dec 2020
    only this, but probably that's not enough. Tomorrow i'll pull out ecu and i'll send picture
    Dec 2020
    My ecu stickers:
    https://ibb.co/1QSZH7v
    https://ibb.co/sjKXff7
    Pls help
    Dec 2020
    Above is better quality
    Dec 2020
    can anyone help?
    Oct 2018
    Default ori file
    if I helped it, paw up
    Dec 2020
    I'll buy galletto v54 and try it
    Dec 2020
    Map does'nt work, car can't start. Does anyone have map for 6 gear?
    SW: 361858
    Dec 2020
    Problem solved, i found it.
