Results 1 to 3 of 3
    May 2010
    Default 2010 FORD e150 - ECU replacement - need help
    2010 Ford E150...
    this car does not have key antenna around the ignition lock cylinder, meaning this car is non pats, the pcm has been changed and suddenly the cluster started blinking padlock light on the cluster, and it gave error code as P1622 please i need help as to how to go about this, because parameter reset was done yet still the padlock still flashes
    Jan 2021
    WASHINGTON DC
    Usually you need 2 keys after pcm replacement. Also besides parameter reset try re-learning the keys. I use forscan or fjds.
    alex_r_2001's Avatar
    Jul 2010
    New Jersey ,, USA
    This car does not have pats antenna.. but you still need to do a parameter reset to match ic cluster to pcm... if you have elm327 or j2534 you can use forscan to do... goodluck
    Solidarity with Ukraine
