Results 1 to 12 of 12
    Member denisajmtdi's Avatar
    Oct 2018
    Romania
    Default Golf 5 1.9 BKC IMMO OFF
    hello agn
    i ve try for over 1 month to do immo off .. finally i buy vag comander and read eeprom.. also immo data too
    now can som1 do immo off for me .. tnx and be safe !
    Dec 2010
    Ro
    denisa,for immo off this car is necessary eeprom for ecu
    Oct 2018
    Romania
    can you verify i posted files ones is eeprom
    Dec 2010
    Ro
    the file posted are from dashboard.if you want to do immo off you have to read ecu.engine control unit.
    Oct 2018
    Romania
    is show locked for me in Can .. when switch to kline not open ... maybe 3.6 vag is too old ?
    Apr 2010
    belgrade,serbia
    eprom is from dash ,you must read eprom from engine ecu
  7. The Following User Says Thank You to vladanr For This Useful Post:
    emanuel2010 (14th December, 2020)
  8. #7
    Oct 2017
    99problems
    If the car is newer than 2007, probably you can not read it via obd with vag commander. Take off the wipers, dissassembly the ecu and read the eeprom from it.
  9. #8
    mobinec's Avatar
    Jul 2011
    EDC16U1 read eeprom with FGTech...
  10. #9
    rafal's Avatar
    Jul 2010
    UK - PL
    this ecu can be done off without removing anything
    need help
    now my goal is to buy xp-005
    who will help?
  11. #10
    Jun 2019
    UK
    HI there , can you help me i have a fg tech and the boards and pins that come with the kit iv made a bdm adapter but it seems it does not work i cant get bdm to read
  12. #11
    Jun 2019
    UK
    hi mate , what tool will do this with out removing the ecu ?
  13. #12
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by leviroots View Post
    many tools read eeprom by obd............also you can use bypass unit
    need help
    who will help?
