Results 1 to 4 of 4
    Dec 2020
    Default Need urgent Confirmation for experienced Tunners
    I have two cars which are mk4 - same year - same KW and same Engine, 1.9 PD TDI engines.
    so i have read flashes from both of them, SW ID is the same.
    can i use to write the flash which is remapped to second car which have SAME SW ID?
    or can you explain with ur words in which cases it's allowed
    Dec 2019
    UK
    Yes, Such an old ECU
    Eight bytes walk into a bar. The bartender asks, “Can I get you anything?”
    “Yes,” reply the bytes. “Make us a double.”
    Dec 2020
    Quote Originally Posted by peechie View Post
    thanks for your reply!
    it should have same SW and same HW , or if the car is same engine Architecture can move the file?
    for example if a car is mk4 - 96 kw TDI PD - 2003 same gearbox - BUT if they dont have same SW and HW is it allowed to write or it will destroy ECU?
    Dec 2019
    UK
    Quote Originally Posted by wikiliks44 View Post
    Must have same SW and HW
    For EDC15 this will do
  5. The Following User Says Thank You to peechie For This Useful Post:
    wikiliks44 (20th December, 2020)
