To me, in particular, the Chinese keys that when read with tango do not indicate frequency. The remote part did not work for me.
Which chip do you have exactly on your chinese key fob?
In the ones I bought there is a chip marked
NXP
26A0700
MM40403
TX6441
Generally with that chip also the remote should work. But only if transponder is correctly prepared (written with correct data by Hitag2 tool).
This was also confirmed here: https://www.digital-kaos.co.uk/forum...key-compatible
I would like to verify my theory I wrote some posts ago (about how CAS3 internal key lerning/programming procedure works).
Could someone please create me an example PCF7945 dump out of the CAS3 eeprom posted here https://www.digital-kaos.co.uk/forum...highlight=cas3 ?
If TMCF Pg3Lock Bit will be zero, then my theory is right.
I will then buy another chinese key and try again to prepare a key with my new knowledge. If it works I will also add a tutorial thread about CAS3 key production with EFFi.
Thanks in advance!
No one here willing to help me with my research?
I only need the PCF dump which can be created from this CAS dump with VVDI tool. https://www.digital-kaos.co.uk/forum...highlight=cas3
Could anybody provide me the dump for preparing transponder?
When I found out everything, I will give back my concentrated knowledge to the forum by making a CAS3 EFFi key programming HowTo.
Sorry mate, don't think you'll find too much response. EFFI is not THE tool for a locksmith to make these kind of keys, more like IM608, VVDI2, etc. This is a locksmith forum, why would one put so much time in creating ways to make a key which you can make easier with the tools available?
Don't get me wrong, I like people pioneering, but for the pro it's not worth it in this case. You try to do things that may not even be possible since remotes are programmed into CAS data most likely using unique data from the key to match to the transponder and so marrying both. You cannot simply add of copy stuff outside CAS standard rules. If that would be so, some developer would have created a 'copy key' function long long ago for this system.
Not to be discurraged, if you succeed to make this happen, thumb up and hats of too you sir.
