Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 96
  1. #31
    Quote Originally Posted by paddy12345 View Post
    just make new folder on SD card named Garmin. in to this folder put map and change name of map to GMAPSUPP.IMG
    but if u want instal map on device ( no on SD card) folder ''Garmin'' should be already there so put a map in to this foler and change name on GMAPPROM.IMG
    just look at this picture Zdjęcia
    cant see picture ill try it agin....
  2. #32
    OK MOVED IT TO THE garmin in garmin folder and then renamed it gmapprom not with the .img on it...just gmapprom and it boost up and says no deatailed maps found that support routing the nuvi cant be used without them? the name of the file in the garmin foiolder befor the oem image was called gmapbmap shall i name the image that name and see if it works nw?
  3. #33
    Top Poster + paddy12345's Avatar
    Jan 2009
    ireland
    Quote Originally Posted by uhaulkid View Post
    that must work, cause I did it plenty times
    right! lets again check everythink
    location
    my_computer\X(garmin device)\Garmin\GMAPPROM
    ensure there is only one ''Gramin'' folder
    enusre folder named Garmin, no garmin
    enusre name of map is GMAPPROM no gmaprom
    enure there is no other map, files namem GMAPROM
    try other map, any small here is map of Bosnia and Herzegovina
    Code: Check this link
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
  4. #34
    location
    yes to all questions....heress a picture of the Garmin folder on the Garmin and its just as you say unless i did it worng but its in right folder its spelled right theres no .img after it....if i do it on the card weith other name i get same thing no mapps on nuvi can proceed....maybe i should start over with regular maps? no it doe snot work at all...i need usa maps but i hope i didnt mess this up for good?
    let me do another picture that one is to small to see....
  5. #35
    Jan 2009
    ireland
    OR this map is Locked!!!! :-////
    try other map
    or try update device
    http://www8.garmin.com/support/download_details.jsp?id=931
    then load a map
  6. #36
    try other map
    then load a map
    when i did web update it gave me text and voice updates options but not fore nglish or amreican? only britsh english? and its still dead...you have msn man maybe you can walk me through getting this back to life i hope...i use this baby daily
  7. #37
    Jan 2009
    ireland
    try other map
    take SD out from the Garmin
  8. #38
    yes but how to try other map...so sorry man but i have never done this at all im lost i can follow directins well but i nee to know what to do here....rtight now it still ays maps not there cant proceed like i have to reinstall eferything
  9. #39
    Jan 2009
    ireland
    HI
    I know u ar bit a nervous but don't worry that must run! today!! ;-)))
    how run other map
    dowanald this
    http://rapidshare.com/files/343093383/GMAPSUPP_BIH.rar
    this is very small map so u can do this very quickly
    unrar this
    do the same as previous, rename map on GMAPPROM put this in to Gramin folder in Device or rename on GMAPSUPP and put on SD
    and run
  10. #40
    Garmin CNE 2010.3b, AR 3.0, SCG 2.10, HUN5.3 Unlocked
    Can someone please join all these maps together & give link???
    Please
    Thank's
  11. #41
  12. #42
    Working for me on a 2gb SD card (as is UK&ROI map 2010) this way!:-
    Create a folder on the SD card called Garmin (capital G rest lower case) - copy the unrar file to it and rename it to gmapsupp.img IN LOWER CASE not caps!
    To use the map goto Tools from opening screen choose settings, then Map, then Map Info and select (tick) the new map.
    Simples
    Thanks for the download info you alls ...
  13. #43
    For the Garmin City Navigator North America NT 2010.10 map I did as instructed but the map doesn't show up in "maps". Also, what are the other files in the download? It has: gmap3d; gmaptz.img; a jcv file; and hashtab.
    Thanks, anyone.
  14. #44
    May 2009
    Smile Garmin Maps
    Hi All.
    Just bought a Nuvi 205w garmin and following "Bananengourmet & Inaccord I've successfully uploaded the maps to a 2G memory card and it worked first time!
    Thanks all.
    Pete
  15. #45
    Thanks for Garmin. Is that Garmin will work on Nokia N900?
