Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 96
  1. #61
    Top Poster Iggie's Avatar
    Quote Originally Posted by nier View Post
    Try to rename a folder "Garmin" in "Map"
    I did everything and beleive me those maps are not OK. Later I found on some other site a good file and it is working now.
  2. #62
    For those having trouble with the images, I think the folder on the SD must be "garmin" not "Garmin"
    Try that and report to help others.
    HTH
  3. #63
    On devices 1xxx the additional map is in a folder "Map"
  4. #64
    Here I have Nuvi 660 and 1300. Maps on 1300 in internal memory are placed in hidden folder ".System". For 660 it is standard in Garmin folder. I tried with SD card and it is OK If you give name to folder Garmin and place the file gmapsupp.img. Also discovered that you can use both files gmapsupp.img and gmapprom.img on internal memory at the same time, so If you have some free space you will not need SD card to split the maps (for example City Navigatior (gmapsupp.ing) and SCG Route (gmapprom.img)).
  5. #65
    guys ive installed the garmin on my phone but when i go into finding places i get error message detailed maps are required to use this feature what have i done wrong i have a file called gmapsupp.img in the root of sd help please
  6. #66
    Sep 2010
    Quote Originally Posted by Devilfish View Post
    Sorry m8, no.
    yes sorry... me too ...
  7. #67
    Sep 2008
    Default Invalid link
    Invalid links
  8. #68
    Jul 2008
    Default garmin nuvi 310
    Hi need help formated my 2g sd card to fat 32 then made a folder and named it garmin capital g then lower case the rest then dropped the 2010 map ito it, renamed the map gmapsup.img in small case letters.The problem is when i switch my garmin nuvi 310 on i wait till the main screen comes on then i press the spanner then i press map then map info and it is not there the only one showing is the one on my garmin itself.Why cant i get the folder up.
  9. #69
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Default [FS][Europe][NT 2012.10][IMG Unlocked] [For ALL Garmin]
    Garmin City Navigator Europe v.2012.10 NT (UNLOCKED) Without Scandinavia (Norway, Sweden and Finland) - Includes the capitals of Oslo, Stockolm and Helsinki - 1,96GB
    http://www.fileserve.com/file/xTq5cCD
    IMG UNLOCKED - Just copy "gmapsupp.img" to SDCard (4GB) -> folder \garmin or to Internal Memory (in this case rename "gmapsupp.img" to "gmapprom.img"). For new models i.e. nuvi 1200, 1400, etc, the folder should be "map" instead of "garmin"
  10. #70
    Is 2011.40 not the latest?
  11. #71
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    will check to make sure i uploaded the correct one
    thanks for letting me know
  12. #72
    Quote Originally Posted by teerak2uk View Post
    I could be wrong, wouldn't be the first time.
    2011.40 is listed on the Garmin site.
  13. #73
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Screen shot from my unit so is 100% 2012.10 version
  14. #74
    New maps are 2012.10
  15. #75
    Jun 2008
    Hi Guys, sorry for not being up to date here.
    I am buying a Garmin 800 to cycle Land's End to John O'Groats, would the garmin maps on here work ok with the 800 as their is a big difference on price between units with and without maps?
    Cheers
