Hi Everyone,
I am a newbie on tuning, i bought a car (MAZDA 3 1560CC 109 HP 80KW 2006) which has been mapped and DPF off by the original owner. and I would like to restore the ecu to the original map and install the antipaticulate Filter.
The problem is that i do not have the original file, i found a file which has the same SW number but i am afraid to flash the ecu and the car does not start again. due to injector coding and key...
EDC16C34/2.2
SW NUMBER 1: 1037379069
FORD HARDWARE NUMBER: 9643626080
FORD HARDWARE NUMBER: 5008050203
Attached you find the file i downloaded from the ecu with MPPS V18 (it is a modified file).
Can you guys help me with the file ?
thank you a lot !
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
Thank you very much for your reply.
mmmm that's why the car has been blowing smoke and regenerating.
You are right the reading is incomplete since i read data only. Please check the new full reading attached file.
I compared it with another file from the same ECU with the same software with HEX COMPARISON, and I do not see any different data.except ROW 007FC0 I am confused !
08 10 18 76 45 03 16 11 05 16 21 06 FF FF FF FF (DOWNLOADED ECU from my car)
08 10 18 76 05 75 20 12 05 13 25 39 FF FF FF FF (ORIGINAL FILE FROM ANOTHER ECU)
can you please check it and report ?
thank you a lot for the support.
here is ori obd read recently
ecuauto (8th February, 2021)
