Results 1 to 15 of 16
    Senior Member el_futte's Avatar
    denmark
    Default read m35080 chip whit galep
    can se my galep5 support m35080 from sgs
    here is my dump write the km is 244302 is this right??
    and can i change it and program on it whit galep whitout problems?
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by el_futte View Post
    You cannot change the dump mate ... You need a new eeprom .. The increment registers will not decrement ( you cannot put in less than is on it ) ...Save the data .. and write to a new eeprom ... then change the miles /KM's ...
    Yeas the kms's are 244k.... 3B A6 > decimal =15270 X16 =244,320
    denmark
    what about if i have a m35080 programmer chana clone can i do it whit that??
    Jun 2009
    I think you can read with galep but can`t write fewer than had been in first 2 strings.If you have chinese m35080 programmer try it and post result to us.
    denmark
    i have program it whit the bmw m35080 programmer now but when i set the cluster 2 the car the km is 999982km
    so is it just set the ews 2 00 and its ok??
    melcool's Avatar
    SPACE
    It seems that you need M35080-Eraser programmer or new M35080 chip!
    BUT
    If you have now in cluster 999982 km...I wonder what would happen if you leave the dash in the car and you drive for 20 Km does it will occur 000002 or 2 km in dash? and after that...increment-programming again the value you need??? Hmmmm ??? or it will stop at 999999??
    Can someone tell????
    Moderator
    PremierD's Avatar
    Jun 2009
    No mate ..you don't ..... I hope you saved the original data ...?Unless the programmer is also an ereaser..And I doubt it... You need a NEW (or one that has less miles than you require to show)...M35080......YOU CANNOT PUT LESS KM'S ON IT ...
    Jun 2009
    It would be nice to see, what is in the dump now.
    DUPNICA BULGARIA
    Omega orange www.scorpio-lk.com work fine with this chip. I use this device for BMW E46, NEW Opel Zafira and..................
    A striking example is М35080.The program module for regular work with it is free, but the program module for irregular operations can be bought in addition.
    This additional program module grants full access to the memory.
    Also there are whole brunches of program modules which automate the process of analysis and alternation of date in memories and processors
    denmark
    now it works i take my bmw 35080 programmer and my bmw ews programmer an first program the chip it works.. and now show the right km. then i use th cas programmer on the cas2 modul and take the right km in it.. but now i get the fault in info board of the bmw about the display maby is damed.. but it works but not show the tank capasity right !!
    so i think the cas modul have 2 be set as the right km as the display showing when it is in the car ?
    Moderator
    PremierD's Avatar
    Jun 2009
    If you have it mate ... post the original dump from CAS unit ....
    denmark
    here you go
  13. #13
    DUPNICA BULGARIA
    This is dashboard dumps. You must post dump from cas.
  14. #14
    denmark
    in the zip there is a ma? thee says temp there it is
  15. #15
    DUPNICA BULGARIA
    Sorry, i dont see the temp directory. Who is you original cas dump?
