Canbus fault.....
good evening,
I scanned to my car a 2018 audi a4 avant b9, I am attaching the scan.
i can't find information about the type of error i find in 19 CAN Gateway and 46 Central Conv.
can anyone help me with this type of error?
1 Fault Found
262659 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Tip-TNF 193007]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 112
Reset counter: 215
Mileage: 83332 km
Date: 2020.11.29
Time: 19:54:50
1 Faults Found
65896 - Databus
U1121 00 [008] - Missing Message
[Tip-TNF 194781]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 113
Reset counter: 215
Mileage: 83332 km
Date: 2020.11.29
Time: 19:54:50
this is the full scan:
Wednesday,16,December,2020,15:56:25:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.4.1.0 HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WAUZZZF4XJAxxxxxx License Plate: SCAN NUOVO CAVO
Mileage: 83332km-51780mi Repair Order:
Chassis Type: F4-AU49 (8W7)
Scan: 01 02 03 08 09 13 15 16 17 18 19 29 36 39 3C 42 44 46 47 52
5F 69 6C 6D 74 81 82 8B A5 AC BB BC CF
VIN: WAUZZZF4XJAxxxxxx Mileage: 83332km-51780miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
29-Left Light -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
74-Chassis Control -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
82-Heads Up Display -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
Address 01: Engine (J623-DETA) Labels: None
Part No SW: 04L 906 026 AG HW: 04L 907 309 L
Component: R4 2.0l TDI H35 1969
Revision: B1H35---
Coding: 0A25403A237605083438
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TDI01104L906026AG 001006
ROD: EV_ECM20TDI01104L906026AG_001.rod
VCID: 6FBBD3A1171EF2A3BA1-803A
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 BD HW: 0CJ 927 156
Component: 0CL 20TDIRdWH05 0001
Revision: --H05--- Serial number: 0000002195
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU49.rod
VCID: 04518C0D2E98E1FB773-8050
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180176000258
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 R HW: 8W0 907 379 D
Component: ESP9 Premium H13 0775
Coding: 0CAA489928A40A9C51A04896008552A2E5B5DA301214508A12 004A45A7AD5B
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 54F17C4D9E78B17BA73-8000
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0251
Coding: 241840195544410D0200010088000000000000000000000000 0000000000
Shop #: WSC 06335 790 00001
ASAM Dataset: EV_AirCondiBHTCAU491 001013
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D14C0D6E1821FB373-8010
Fresh Air Blower Front:
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002587391
Relative humidity sensor in fresh air intake duct:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 3E51173900PAG0MUFU02
Rear Climatronic Operating And Display Unit:
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501343C13900CD0505511958BF88F9130B31080000000000 000000600016810A4502AB22B70A
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_018_AU49.rod
VCID: 025D8A15348CEFCB45F-8056
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 180603 043 0813
Serial number: 89435300301815404220
Coding: 5BC7F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 21581220X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AH HW: 4M0 941 531 AH
Component: E1 - LDS H06 0008
Serial number: 10 04 2018 01395439
Automatic Day Night Interior Mirror:
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE130041823611166
Coding: 030000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00873076
Convenience And Driver Assist Operating Unit:
Subsystem 6 - Part No SW: 8W0 925 301 BF HW: 8W0 925 301 BF
Component: SL-B9/Q5NF H17 0010
Serial number: 2818000068069004
Coding: 000000
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 C HW: 8W0 907 561
Component: LRR4 H10 0340
Coding: 3477FFFB58FFEC0A959A81A0
ASAM Dataset: EV_ACCBOSCHAU49X 003022
ROD: EV_ACCBOSCHAU49X_003_AU49.rod
VCID: 3E253EE500F44B2B617-806A
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0107
Serial number: 003UP00HPC1R
Coding: AACCF0C00C800000985400F3D04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 4CC1642D4648E9BBFF3-8018
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 8W0857705F0180S00831
Coding: 88001B
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 8W0857706G0183S00500
Coding: 88001B
Side Sensor Driver Front:
Subsystem 3 - Part No SW: ----------- HW: 442 060 107 18
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y009F27DBDE2E21U
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 4 - Part No SW: ----------- HW: 442 060 107 18
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y009F27DBDE2E12V
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 906 18
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700A52B0ECB5039J
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 906 18
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700AB2A7757443EM
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 906 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B92AD0174C3EP
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 906 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B92AD0174C1EO
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 906 18
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500B92AD0174028+
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 10 - Part No SW: ----------- HW: 442 431 606 18
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00C72771D0402C9
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 11 - Part No SW: ----------- HW: 442 431 606 18
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00B7272ABA432CO
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 ME HW: 4M0 907 129 ME
Component: Lenks.Modul H11 0009
ASAM Dataset: EV_SMLSKLOAU736 006008
ROD: EV_SMLSKLOAU736_006.rod
VCID: 7F5B03E1477E82232A1-802A
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H19 0377
Coding: 058D69C07C98000800A3E9601000600000000000
ASAM Dataset: EV_DashBoardAU736 001027
ROD: EV_DashBoardAU736_AU49.rod
VCID: 43D34F116B1626C30E9-8016
Address 18: Aux. Heat (J364) Labels:* None
Part No SW: 4M0 265 105 E HW: 4M0 265 105 E
Component: HSG H11 0090
Coding: 0D0B01
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
ROD: EV_AuxilParkHeateEBEAU736.rod
VCID: 290FFDB9E97ADC93245-807C
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 8W7 907 468 F HW: 8W7 907 468 E
Component: Gateway H42 0123
Revision: 7C000001 Serial number: 0187C827718706
Coding: 03010001000006404107000000590012DC9800071000000001 75078F10000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 4EC56E25B054DBAB917-801A
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180706062025 30501
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 9486798404
1 Fault Found
U1111 00 [008] - -
[Tip-TNF 193007]
Freeze Frame:
Fault Priority: 6
Reset counter: 215
Mileage: 83332 km
Date: 2020.11.29
Time: 19:54:50
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D
Component: LCM_MLBevoH05 0024
ASAM Dataset: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW48.rod
VCID: 79AFEDF9595AAC13145-802C
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0042
Serial number: 00000332453577
Coding: 00581B000000B0010000010101010000000000000000000000 000000000000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006009
ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 E HW: 4M0 907 566
Component: MRR1Rear H20 0430
Revision: --------
Coding: 1EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 372B2BC12FCE7A63A21-8062
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0130
Serial number: 0000329988489
Coding: 005D0B215E00008000001030
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 0D888380008080
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 42DD4A15740C2FCB05F-8016
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 EC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 025 0387
Coding: 01340000002000E06309A0000E00480233004000804F06502F 0400000504803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
VCID: 015F8519318AF4D35C5-8054
Sensor Controlled Power Rear Lid:
Subsystem 1 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: 12049740
1 Faults Found
65896 - Databus
[Tip-TNF 194781]
Freeze Frame:
Fault Priority: 6
Reset counter: 215
Mileage: 83332 km
Date: 2020.11.29
Time: 19:54:50
Supply voltages-Supply voltage: Terminal 30: 12.405 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.446 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.419 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 91 04 5A 12 02 98
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAJJA04JWCS
Coding: 0194020800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
VCID: 76B5E6C56844C36B797-8022
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0130
Serial number: 0000330253101
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
1 Fault Found
196630 - Heated Exterior Mirror
B11F8 14 [008] - Open or Short to Ground
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 215
Mileage: 83332 km
Date: 2020.11.29
Time: 19:57:48
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8W5 035 035 B HW: 8W5 035 035
Component: MU-P-LND-EU 034 1177
Serial number: A829F0JB077964
Coding: 019402010000000053111102000A00102F0002E5017001009E
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
VCID: 363526C528C4836BB97-8062
Data medium:
Subsystem 1 - Part No SW: V03 959 802 TL HW: -----------
Component: ECE 2020/2021 --- 0187
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0170
Serial number: TPO00119051800820448
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK127061800040907
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 F HW: 4M0 907 383 B
Component: Anhaenger H27 0253
Revision: 9A001003 Serial number: 0485473282
Coding: 0110000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW37.rod
VCID: 353721C935C28873B0D-8060
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 F HW: 4M0 907 428
Component: Areaview 2 H13 0318
Serial number: C854607JG067740
Coding: 02940201BF0FA10008404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0166
Revision: -------- Serial number: 32016594500000
Coding: 05F0
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW37.rod
VCID: 323D1AD5C4AC9F4B95F-8066
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 H HW: 8W0 907 777 C
Component: Fahrwerk-SG H37 1214
Serial number: 0207181268
Coding: 9050504958
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 N HW: 8W1 713 041 K
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 18070647796854
ASAM Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSMWaehlZFAU736.rod
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 8W5 919 617 B HW: 8W5 919 617 B
Component: HeadUpDisplay H18 1640
Coding: 4F01C0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 47CB5B015F2E0AE3D21-8012
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 C HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 003022
ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
VCID: 3C2134ED16E8593B4F3-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 C HW: 8W0 907 217 C
Component: BVS H18 0050
Coding: 0404090200000402022023A7CD0000FCB0F0C020E280
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0006
ASAM Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736_AU49.rod
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 E HW: 4M0 907 590
Revision: --------
Coding: 1EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 34311CCD3EB8917B873-8060
End----------(Elapsed Time: 02:25, VBatt start/end: 12.1V/12.1V)-----------
Canbus fault.....
hi, thanks for the reply.
I tried to investigate the failure, I do not think it is a real failure, weight is a problem of sleep mode, in my opinion the j605 control unit, would be the 6D Trunk Elect. , it switches off before the control unit 46 and sends both 19 and 46 into error.
can you tell me how to delay the sleep mode on the 6D Trunk Elect. ECU?
