Results 1 to 5 of 5
    Junior Member jarvismaster's Avatar
    Oct 2020
    Russia
    Default [REQUEST] BMW E60 525D Stage1 + DPF OFF + EGR OFF
    delete pls, solved, thanks
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by jarvismaster View Post
    Hello Everybody!
    I have one BMW E60 525D 177hp 2497cm3 6AT tuned to Stage 1, DPF OFF + EGR OFF + Popcorn Limiter
    Recently I updated my ECU, and lost the tune (my bad, no backup)
    The car is:
    * stock gt2056v (electric) turbo, good condition, no axial play
    * stock injectors
    * straight piped (no dpf, no cat, 70mm exhaust from turbo, without mufflers)
    * swirl flaps removed
    * egr blanked
    Can someone help me, to (re)tune my file to Stage 1 ~215hp or little more 230hp with egr off + dpf off + popcorn? (if it is safe)
    ECU Parameters:
    EDC16C31
    HW: 0281012190
    SW: 1037390905
    The file is KESS V2 Backup
    (This is 25D 177hp, not 30D, I know 30D with same hardware & software, but different maps)
    Thank you very mouch!
    thank you very much
    No file has been posted
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  3. The Following User Says Thank You to chrisimerk For This Useful Post:
    jarvismaster (29th December, 2020)
    Oct 2020
    Russia
    Sorry sir, now I uploaded to my google drive and posted the link
    May 2017
    Automatic transmission and popcorn ...
    Be more active and dont only request and you get help for sure.
  6. The Following User Says Thank You to Lambda1 For This Useful Post:
    Oct 2020
    Russia
    delete pls
