Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    DeLuXe's Avatar
    Mar 2019
    Default VW Caddy 2017 - MQB key from cluster + ECU
    Hi!
    I have a VW Caddy 2017
    The customer sent in Instrument/Dashboard (ST 24C64 is read)
    ECU: VW AG 04E 907 309 BM
    Dash: 2K5 920 876 G
    Is it possible to make a MQB key from both these so that I can send working key to customer?
    Do I need to read the ECU as well because it seem to be only Dashboard that is immobilizer.
    Thanks in advance for all the help!
    Best regards,
    DeLuXe
    Sharing is carying. Please press Thanks + Rep Button if my post is helpful
    rob h's Avatar
    May 2011
    Yes, it should be possible, if you have the experience and proper tools.
    Is this car with manual, or dsg automatic gearbox?
  3. The Following User Says Thank You to rob h For This Useful Post:
    raskolnikov1975 (28th May, 2022)
    DeLuXe's Avatar
    Mar 2019
    I got plenty of tools, if the car would be here then that wouldnt be any issues.
    The car is a manual transmission.
    Thanks for the help!
    Best regards,
    DeLuXe
    Usa
    hi
    best for PQ uds with id88 is UHDS in service mode,or with ZED FULL online calculator.
    DeLuXe's Avatar
    Mar 2019
    SMOK series tools and Zed full is about the only ones I dont have.
    No one here that have such service? I can happily pay
    Best regards,
    DeLuXe
    DeLuXe's Avatar
    Mar 2019
    I think problem will be solved. Ordering MQB VAG test plattform cables.
    Thanks for the help.
    Best regards,
    DeLuXe
    Supas's Avatar
    Jun 2020
    If you are interested ... With photo of ECU and VIN I can deliver Inmodata to finish the job with vvdi2. Prepare dealer key and program ...
    DeLuXe's Avatar
    Mar 2019
    That is absolutely interesting. Please do send me your contact details, whatsapp would be great ��
    I've purchased MQB Test platform cables and recieved them. Connected ECU + Instrument Cluster, switched button ON. But I could not connected to either ecu or instrument with VVDI2 to collect needed data for MQB.
    Have I missed something ?
    Best regards
    DeLuXe
  10. #9
    Supas's Avatar
    Jun 2020
    With the correct inmodata file that I obtain from the simulation of the system with ecu photo + vin number and using you as the vvdi2 tool, only with the board on the bench and the correct procedures can you program your distributor keys and register them. .. Being an MQB 4.5 system, it is not necessary to get any security component other than the dashboard and ecu to prepare a dealer key even if your vehicle is automatic. Everything changes if your board would be with 35xx ... there it would be necessary to obtain sync data. I send the data requested by MP
  11. The Following User Says Thank You to Supas For This Useful Post:
    DeLuXe (16th January, 2021)
  12. #10
    DeLuXe's Avatar
    Mar 2019
    Thanks for your help and useful post my friend. Much appreciated!
    Best regards
    DeLuXe
  13. #11
    fred77's Avatar
    Jun 2019
    What tools u have?
    Found AVDI, VVDI (yeah clone annoyed) and Autel let me down esp AND ZED FULL currupted dash
    (YES ZED FULL left me with a non-running car !!! for 24-hours till support help)
    All Think cos immo 4 with MQB - hope u have better luck
    Bought SMOK
    EDIT:
    Mate i had no connect with VVDI either really this tool has been a disappointment
    Solidarity with Ukraine
  14. #12
    DeLuXe's Avatar
    Mar 2019
    Hi all,
    News and help needed please.
    So I bought a used gateway module and hooked it up. All good. Connection to both ECU + Dash without any problems.
    The car is All key lost, VW Caddy 2016/2017..
    Couldnt make "All key lost" module option on VVDI2 because couldnt get PIN from ECU either automatically or manually.
    NEC+24C64 eeprom is readed with programmer on bench.
    Cant read either EEPROM or IMMO Data with VVDI2, security login fails everytime.
    How can I solve this annoying task it has become?
    Is it possibly to maybe get original file request for this ECU and pair it with the dashboard somehow to make a key?
    Or is there any other option?
    Thanks in advance,
    Best regards,
    DeLuXe
  15. #13
    DeLuXe's Avatar
    Mar 2019
    Nobody here offer MQB All key lost - Sync file via Data collection 01 + 17 ?
    Payment ofcourse.
    Thanks in advance,
    Best regards,
    DeLuXe
  16. #14
    prevozsa's Avatar
    Mar 2015
    Bosnia
    need vag obd helper
  17. #15
    put the dash in service mode by eeprom dump it vvdi2 than you can read immo data!
