Results 1 to 15 of 17
    Feb 2016
    Default Audi A3 1.9 TDI 8P0 920 900 D
    I have a reference frame 8P0 920 900 D of an Audi A3 1.9 TDI from 2003 with corrupted software, the left display is incomplete and DEF on the right, is there a way to repair it, I attach the file read with avdi
    Thank you and happy new year
    Aug 2016
    Read eprrom 16 bit no flash
    And put here
    AVDI It has repair options Def function specifically
    Feb 2016
    This was the file I had before modifying it
    Feb 2016
    Default Audi A3 8P0 920 900 D
    Original reads and scrapping in 16 bit with Xprog
    Aug 2016
    Do you remember odo 269312?
    Feb 2016
    Yes thatīs the original
    Feb 2016
    The original box turns off and on repeatedly and when recording the original file to the scrap file, it is when the scrap file has gotten wrong, it doesn't go with either of the two files.
    Aug 2016
    Save file And let me know
    Feb 2016
    I have saved the modified file and I have fed it in bank pins 1 and 2 to positive and 3 and 4 to negative but the displays do not turn on, is it normal?, I have to put in vehicle and wait? , Thanks a lot.
    Feb 2016
    Nothing, the car does not start and the dash remains the same with the incomplete clock display and the other diplay with DEF
    Aug 2016
    Quote Originally Posted by AREA22 View Post
    Hello
    Here you have an instruction can help you
    Feb 2016
    It is not to adjust km, it is to clone dash, the problem has been when recording the information from the original to the scrapped
  13. #13
    Aug 2016
    Yes I know but yours does not work although it looks like a good wr ironing
    http://wiki.ross-tech.com/wiki/index...ument_Cluster)
    It seems to me that it has been damaged with AVDI and the same replacement eprrom can not do anything.
  14. #14
    Feb 2016
    I believe that the software is corrupted for whatever reason, let's see if I can locate the complete software to see if it is fixed.Thank you very much for the interest you are taking.
  15. #15
    Aug 2016
    But not with AVDI.
    Use a different tester
