how remove ubuntu Bootloader ?
Results 1 to 9 of 9
    Top Poster kuwaiti's Avatar
    Feb 2011
    Kuwait
    Default how remove ubuntu Bootloader ?
    hi
    i instaled Ubuntu in same HHD as windows 7
    and uninstal it from add/remove program but each time i boot my pc i get screen to chose win 8 or ubuntu (ubuntu already deleted
    help .
    Jan 2013
    Bucuresti
    Set your BIOS to boot from CD or DVD drive
    -Put your Windows installation disc into your CD or
    DVD drive
    -Boot up your computer and start from CD
    -Select a language, a time, a currency, a keyboard or an input method, and then click Next.
    -Click Repair your computer.
    -Click the operating system that you want to repair, and then click Next.
    -In the System Recovery Options dialog box, click Command Prompt.
    -Type Bootrec.exe /FixMbr, and then press ENTER.
    Reboot your computer
    Feb 2011
    Kuwait
    Default thanks
    Quote Originally Posted by Mihairece View Post
    DVD drive
    did not work
    but just solve it a minute ago
    - Click start
    - Type: cmd
    - Right-click cmd when it appears under Programs
    - Click Run As Administrator
    Once the prompt is up type bcdedit.exe
    this will list all of the OS that start up in Windows Boot Manager
    Once you have this list you use the command bcdedit.exe/delete file name
    example: bcdedit.exe/delete {802d5e32-0784-11da-bd33-000476eba25f}
    but thanks
  4. The Following User Says Thank You to kuwaiti For This Useful Post:
    M T Glass (26th July, 2015)
    Feb 2013
    Glad you fixed it..
    But for those who want to fix there MBR without Windows disc.. you can also use Rescatux (SuperGrubDisk)
  6. #5
    Newbie VegaWorks's Avatar
    May 2015
    Italy
    Edit the boot.ini file, you'll get something like this:
    [boot loader]
    timeout=3
    default=multi(0)disk(0)rdisk(0)partition(1)\debian
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="debia n" /noexecute=optin /fastdetect
    c:\debian.mbr="Ubuntu"
    Delete (after a backup):
    Otherwise, with a live CD as Ubuntu:
    "sudo ms-sys --mbr /dev/sda"
    If you prefer you can try also using freedos with a "fixmbr"!
  7. The Following User Says Thank You to VegaWorks For This Useful Post:
  8. #6
    Jun 2018
    Virgin Islands
    thanks to you both. but im still working on it. im not sure what happenedcan you please tell me how to change from ubuntu 8.04 to 8.10.
  9. #7
    Jun 2010
    Europe
    We're in 2018 and you are still using Ubuntu 8.04 from 2008? I guess your quite out of luck if you want to "upgrade" to 8.10.
    First number in Ubuntu release is year, second number is month so 8.04 is April 2008...
  10. #8
    Jul 2019
    Download the tool and run it.
    sudo apt-add-repository ppa:yannubuntu/boot-repair
    sudo apt-get update
    sudo apt-get install -y boot-repair
    boot-repair
  11. #9
    toyota123's Avatar
    Sep 2019
    try with live usb .... and repair.... easy solution with blackarch
