Results 1 to 7 of 7
    Dec 2020
    Default E46 320D 150hp stage 2
    Hi, can you make strong stage 2 for my 320d?
    Turbo about 1,7 bar
    May 2017
    maybe if you got a strong increase of quality posts
  3. The Following User Says Thank You to Lambda1 For This Useful Post:
    Pyromaniak (7th January, 2021)
    May 2019
    try and report don't forget put a thanks and rep button
  5. The Following User Says Thank You to dzejkoff For This Useful Post:
    jfk84 (22nd November, 2021)
  6. #4
    Dec 2020
    There is problem, turbo pumps only 1,55bar... Did u know why? maybe n75 maps?
    May 2019
    Well if you put another turbo or hybrid turbo should be change little bit n75 with logs
  8. #6
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by admw00 View Post
    24psi is easily achieved with standard turbo no need for hybrid something wrong with file Provided capping it at 21psi turbo limiter not done correctly missing svbl or missing boost limit maps a few things can pull boost if not done properly ie too much fuel pressure or duration etc
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  9. The Following User Says Thank You to chrisimerk For This Useful Post:
    admw00 (11th January, 2021)
  10. #7
    Dec 2020
    I have to try... too much fuel can slow down turbo?
