Results 1 to 2 of 2
    Jan 2014
    Default Mercedes 3.0d engine problem
    Hello , friend of mine have a problem with Mercedes 3.2 CDI engine. On idle is working perfect , when you push the accelerator pedal above 1400rpms the engine non stop cuts off from fuel pressure regulator.
    all 6 injectors are tested on injector stand machine are ok
    fuel pressure regulator replaced 2 times
    fuel pressure sensor replaced
    high pressure pump replaced
    2 different ECUs tested with original software dump
    No dtc codes are stored
    fuel lifting pump tested
    When you turn 1/4 back the fuel pressure regulator from its tread the engine can run in all rpms but only standing /not in motion/.
    Somebody have a idea what to check?
    Thanks in advance
    Jun 2013
    Look backup pressure sensor
    Wysłane z mojego SM-G398FN przy użyciu Tapatalka
