    Apr 2018
    Default Peugeot Partner 2004 speedometer and mileage not working
    I have trouble with Peugeot Partner 2004 1.4 TU3JP, speedo and odo is dead.
    I checked:
    -wirings (sensor-BSM ok, BSM-BSI ok, BSI-cluster ok)
    -speed sensor (is new and singal in osciloscope is ok)
    -instrument cluster (i change to other used cluster and the same, in speedometer test needle is running)
    -radio (unpluged)
    In PP2000 in ECU measured values km/h is always 0.
    In PP2000 in instruments is DTC: wrong signal from speed sensor
    ECU was changed because i open it and as in the photo is holes from searching eeprom maybe some repairs.
    What is the signal path from the sensor? SENSOR-BSM-ECU-BSI-INSTRUMENT? If yes, I suspect the ecu is damaged.
    Do you have any ideas what to check and what could be the reason?
    Attached photo of ECU and wiring diagram. Red is signal, green + to sensor
    stoyanov's Avatar
    42 75 6C 67 61 72 69 61
    I had a similar problem with Peugeot 406 and Sagem S2000 ecu.On this car most probably was changed engine ecu and there was fitted non compatible S2000 ecu.Check identification on engine ecu label,maybe you have the same problem.
    Sep 2010
    europe
    Hello !
    Check configuration on engine ecu: speed km abs or w/o abs.
    Best regards, Tom
  4. The Following User Says Thank You to peumis For This Useful Post:
    kamaz007 (11th January, 2021)
    Apr 2018
    Quote Originally Posted by peumis View Post
    Hello !
    Best regards, Tom
    I don't have this option on ecu config.
    Quote Originally Posted by stoyanov View Post
    I have S2PM -372 in car, should be a S2000? I think this is the problem.
    Feb 2011
    I think problem with BSI.
    Use speed generator,and check wire.
    If I helped, use magic buttons reputation+thanks.
    Best regards.
    Apr 2018
    peumis was right. I found coding for ECU: multiplex digital ABS or simple wired ABS, i check wired ABS and uncheck speed control or something similar and speedo works
    thanks for all hints
