Results 1 to 13 of 13
    Mar 2019
    Default Rns 510 language message
    Hello any idea why the RNS shows the langueage issue? The desired language could not be loaded
    dec123ua's Avatar
    Nov 2015
    Kiev, Ukraine
    try to update firmware
    Mar 2019
    I made upgrade and also check the ssd but problem is still the same. Somebody mentioned to "update the FW with full init" But i dont know ehat does it mean.
    Mar 2019
    somebody adviced its NAND Flash issue. Which nand should i erase?
    There are two 29f1g08
    There is 29gl032
    Also m29w160 and m29f400
    Have no idea in whis the language pack is stored....
    Oct 2018
    Quote Originally Posted by TESTASTRETTA View Post
    There is 29gl032
    Which firmware installed now ?
    Dec 2018
    hello,
    same issue here, any help?
    dec123ua's Avatar
    Nov 2015
    Kiev, Ukraine
    Quote Originally Posted by tmm47 View Post
    hello,
    read my previous recommendation one more time
    Dec 2018
    Quote Originally Posted by dec123ua View Post
    Hi, i did an update with same firmware 6276 but didn't solve the problem! how to downgrade to 6270? thank you
    dec123ua's Avatar
    Nov 2015
    Kiev, Ukraine
    direct from SWDL mode
  10. The Following User Says Thank You to dec123ua For This Useful Post:
    tmm47 (22nd June, 2021)
  11. #10
    Dec 2018
    hi again, i dve done it direct from swldl mode but the same, problem persists; everything in german; any help please?
  12. #11
    dec123ua's Avatar
    Nov 2015
    Kiev, Ukraine
    use firmware with init
  13. #12
    Dec 2018
    how to do so?
  14. #13
    Oct 2018
    There is 29gl032
    There are two 29f1g08 this is NAND
