Results 1 to 10 of 10
    Dec 2020
    Default Citroen C4 Lounge - BSI Continental BSI-Q04 - 95256 - Odometer change
    Just dumped the chip 95256
    Mileage should be 17445x km
    I was able to edit the dump from the cluster no problem using NYO 4.0 2017 but couldnt with the dump from the BSI
    Please edit to 121350 Km
    Thanks!
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
  3. The Following User Says Thank You to jomberykaso For This Useful Post:
    Pacote (9th January, 2021)
    Dec 2020
    Quote Originally Posted by jomberykaso View Post
    Thanks a lot!
    Not trying to bug you anymore but the pin code is KCOL correct? (I found KCOL twice and J85H Once with hex editor so I THINK it should be the one that shows up twice right?)
    Jonatanfunes91's Avatar
    Jun 2020
    Argentina
    Hello colleagues, can you read the memory 95256 with upa 1.3? Do you have to make a board too or just bsi? I have a C4 lounge 2015
    death9891's Avatar
    E.U.
    Hello. I need a PIN from this BSI
    peugeot 508 2011r Continental BSI Q05-00
    95256
    Mooti's Avatar
    Nov 2018
    try pin 5344
    death9891's Avatar
    E.U.
    Quote Originally Posted by Mooti View Post
    try pin 5344
    This is not an immo pin
    is the ending of vin :-)
    Bllinda's Avatar
    Baltic
    .... Lock ....
    today
    A topic that interests me
  10. The Following User Says Thank You to Bllinda For This Useful Post:
    PremierD (9th August, 2021)
  11. #9
    death9891's Avatar
    E.U.
    Quote Originally Posted by Bllinda View Post
    .... Lock ....
    Not LOCK
    in another file at a colleague from 1 post there is also LOCK
  12. #10
    death9891's Avatar
    E.U.
    Quote Originally Posted by death9891 View Post
    Not LOCK
    pin visible in BML module resolved.
