Results 1 to 4 of 4
    Jul 2019
    Philippines
    Default passat b5 1.9tdi 101ps stage 2
    hi, someone of you has a stage 2 file to passat b5fl 1.9 101ps. this car has a turbine with 130ps ash. this ecu is already stage 1 and I want stage 2.
    -manual transmission-
    Best regards
    May 2017
  3. The Following User Says Thank You to Lambda1 For This Useful Post:
    domins (9th January, 2021)
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by domins View Post
    Best regards
    here you go dyno tuned stage 2 with your specs
    enjoy
    pass in pm
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  5. The Following User Says Thank You to chrisimerk For This Useful Post:
  6. #4
    Jul 2019
    Philippines
    thanks all. I'll check on Monday I give feedback
