I think so, that KTM is the problem. I made EDC17c60 before with KTAG and there wasn' any problem. CK are Ok but You are wright -there might be in patch problem. If it is not problem I will send files tommorow to patch. THANKS!!!
Do You think DTC off will solve problem? I think that dtc will not show up but car still wouldn't start...
Upload the file, i will fix this for you, its tprot problem
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
Int. flash
I had to attach files using MEGA server. I'm not ableusing android attach files normally
https://mega.nz/file/Mt8QSDTT#CCIcXP...pgaTSVUcPYJWWs
If my solution helped You - do not forget to THANKS !!!
TPROT 13 off
number7hd (11th January, 2021)
dtc off and mask off will work too and car will start
but and patch is easy to do
Sent from my 5033F using Tapatalk[/QUOTE]
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
I had the same problem on EDC17C10 PSA, i read with flex and after that i try to write also with flex and have problem. (bench) After that i try with ktag and everything was fine. I was making DPF + ADblue off.
here is your file with tprot off
luismccunha25 (7th September, 2022), number7hd (11th January, 2021), sonic 1989 (12th January, 2021)
