And the computer detects it?
Try to update it via WOW.
Wow does it better.
Wow does it better.
fady eid (12th January, 2021)
You should be able to reflash again. If VCI is red then there is a good chance it will carry on where it left off when you start to flash again. They are pretty hard to kill unless it is a hardware fault.
Your copy of delphi may also be setup for another VCI like 100251. You can edit installation.xml with your VCI serial and you will need Hardware ID to match that serial, then reactivate.
HaynesPro online + 2022.02a version available, message for where to get it!
yes pc recognize it ok and also the program delphi or wow detects it but cant update by both wow and delphi and cant show correct firmware now
while it updating it stopped at 50% now it didnt respond to update just receive msg plug usb or power supply
is there a way to reflash the 29f900 ? or what to do as i think this is possible way now only
You can download other firmwares HERE , drivers HERE and HERE they need to be the same in both delphi and wow so copy firmware folder to wow/ac_diagnosis_module folder.
Update can only be done through USB and not bluetooth.
Try update again with different firmware.
You also need VCI plugged into a car or 12v power supply!
i will try again to remove the 2016 version and install 2013 and give a try , my questions is how to know my firmware number now after it crashed ?!
hi thank u so much for help i need your help now i think its firmware problem or blacklisted pls check the photos i have tried many pcs , different cables , power suplly
i cant find the installation .xml could u tell me the path of this file
inside the xml file serial is 100251 what should i do know !?
i used software to detect the serial it was 30250 many people after my reserch ask to install old version autocom 2011,1 to do update there what is your opinion
