Typical problem, if you scan DTC you will find P1259.
You have 2 options here...
1. You can read ECU with BDM TOOL (KTAG BDM100 FTECH ETC and post the files
2. Or you can buy a replacement ECU (€170) and sync immo with diagnostic tool for example FORD IDS
What tool did you use to read and write?
I had a failed write on ford fusion 1.6 TDCI EDC16C34 and recovery option on kess clone 5.017 worked fine
