Col19 (10th September, 2021)
Short answer is not that i can find....
But there was a guy on ebay who sells them.
Pity scanmatik buying options are only in russia.
HaynesPro online + 2022.02a version available, message for where to get it!
"CHIP-Tuning - PCM Flash :: Sklep@AutoDiag.pl" http://www.autodiag.pl/index.php?k88...ning-pcm-flash
"CHIP-Tuning - PCM Flash :: Sklep@AutoDiag.pl" http://www.autodiag.pl/index.php?k88...ning-pcm-flash. In my country, the store has on offer. I wonder about it myself. It is a bit more expensive than in Russia but without customs duties. By the way, I have a question. Having scanmatik for pcm flash and bench cable for module 53 and 71, do you still need a power box?
kfz09 (31st August, 2021)
I'm not going to power the ecu from usb . The cable for bench modules 53 and 71 has a plug for the power supply . I am asking for a power box or CombiBox because I saw how the guy had a scanner connected to the power box and from the power box to the ecu. He was doing the ecu from the Hyundai tucson gasoline I don't remember what ecu. On other videos, they do edc17 without a power box. That's why I asked a question.
How it's possible after all this time Pcmflash is in commerce and people uses it, that there are still some people believing you need powerbox in order to make SM2 work?
SM2 works perfect in module 53, 71 and 77 also with Bench Cable (the genuine one made on purpose for these SM2 modules), it has power plug, automatic control and GPT signals, you really don't need other equipment.
Plus on Youtube or web you can find thousands of videos or pics that shows Pcmflash working only with SM2 and Bench Cable..
macpro (27th August, 2021)
i confirm, scanmatik 2 Pro and the bench cable for sm works fine, no need any further equipment..... and of course have and plug for power....
if you google for pcmflash, you should find a company the second synthetic is tuning.com?..... they send from USA and from Ireland, so no problem with taxes... (i never had take anything from them....)
Hi friends
the price has risen sharply.
Greeting.
