Results 1 to 4 of 4
    Nov 2013
    Default Honda FR-V door central power locks issue - wiring diagram?
    Hi all,
    Does anyone have wiring diagram for Honda FR-V? My central lock actuates but locks immediately again. Takes around 20-30 attempts before it unlocks the doors.
    Meat-Head's Avatar
    So unplug each active point one at a time
    Jun 2019
    Aussie
    check the actuators, if all ok its likely a relay fault/bad solder joint in the multiplex module. easily repaired if you are good with electronics
    Nov 2013
    I just replaced driver door lock mechanism and it solved the problem.
