Results 1 to 8 of 8
Thread: Mitsubishi L200
    Croatia
    Default Mitsubishi L200
    Hello
    Need help to make new key if is possible.
    Car is Mitsubishi L200 2.5Diesel 2001.year.
    Ecu is MD351418 and immobox is MR301010 with processor HC805,as i see this processor is not possible to read with orange,smok,beeprog,xprog and so on....he need specify programmer to read it.
    So by obd it can be program new key or not ? I have avdi,skp9000.If i can with SKP9000 do i need pincode or something that i can program key ?
    Thank you ...
    Mar 2018
    UK
    Usually Mitsubish use fixed code
    try to program it with something old wike SBB or T300 - they must know the code
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    Mezz_cro (14th January, 2021)
    Dec 2010
    Nottingham
    try pin code 3828 on models up to 2006 if not known by your programmer . as has been said T300 or sbb will do this , avdi will struggle as avdi only covers canbus from 2005 models.
    what ever you do once you turn ignition on with your new key , do not switch ignition off again until the key in ignition is programmed otherwise you will lock ecu , if ecu locks you must leave ignition on for 25 minutes to unlock ecu , then code key .
    so if you have already turned ignition on and off with uncoded key then ecu will be locked , when ready to code key turn ignition on then leave it on for 25 minutes then code key before turning ignition off .
  5. The Following 4 Users Say Thank You to rapidlocksmiths For This Useful Post:
    Alpaholic (15th January, 2021), Manta1600 (14th January, 2021), Mezz_cro (14th January, 2021), Weasel3 (14th January, 2021)
  6. #4
    kemaster's Avatar
    BG
    Just to add to Rapid, when switching ignition on with unprogrammed key clear fault codes.
  7. The Following 2 Users Say Thank You to kemaster For This Useful Post:
    Mezz_cro (15th January, 2021), Weasel3 (14th January, 2021)
  8. #5
    Croatia
    Transponder for this car is 4D61,correct ?
  9. #6
    autochei's Avatar
    Mar 2013
    romania
    no tools can program tp for thys car u need tmpro with special adaptor to read 805p18
  10. #7
    Dec 2010
    Nottingham
    Quote Originally Posted by autochei View Post
    this is not correct , mvp pro and smart pro program these old L200 1999 to 2006
    models 2000 to 2002 , id60
    models 2002 to 2006 , id61
    but this is a rough guide as seen id61 on 2001 models more than id60 here , but this is uk models i refer to.
  11. #8
    Feb 2014
    portugal
    hi
    make it by obd,with zedfull or sbb ,4d61 transponder,
