Which tool you using?
File Service
Stage 1/2 (with logs)
EGR & DPF
+ More
I read and write willem.
winols checks the checksum and says it's okay but not really good, the car doesn't start
Your checksums are ok.
probably you bricked your ecu that's why it won't start. Checksum are good but I see couple bits changed in calibration section that might your ecu got stuck
you mod file is wrong for that not start car
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Hello friend againI did as you said, I uploaded the original file and the car started reversehow do you think why it iee works
Maybe some kind of willem issue?
Are you using the same Flash (erasing and then programming) or are you using two different memories?
It is better to arrive 10 minutes early, than to be bored all the way.
yes i use erasing and then programming
Thanks.
I have tested in winols ecm (tita, 6.3, ultimo csk corrector) and all o them say csk ok. Maybe a issue related to data organization (swapp in willem software).
Hav you tried to read by k-line?
k-line reads not full flashI want to turn off the error p0172
it seems to me that the modification of the file is incorrect
I just uploaded the file to the new flash bone but it's still the samethe first time the car starts but the revs start to wave, ABS esp messages appear and stops workingthe restart fails.
as I write ori, the car works ok
Then, as long as I know there are two option (or causes).
- After writing the Ecu, you will need perform a some king of configuration. DTCs after witing?
- The data that has been modified are out of the checksum range (this is a fact). You will need adjust manually the checksum. (I think only a few people can do that).
so you can not do anything?
