Results 1 to 5 of 5
    Oct 2016
    Slovakia
    Default Passat 3C clear defect 25C640
    Hi, please clear defect
    0003 - Control Module 014 - Defective - MIL ON
    3C0 909 605 M HW: 3C0 909 605 M
    Component and/or Version: 0B AIRBAG VW8 031 2522
    Software Coding: 0012354
    Aug 2016
    Test...... ().....
  3. The Following User Says Thank You to lukasz12345 For This Useful Post:
    jokir (15th January, 2021)
    Oct 2016
    Slovakia
    DTC- 0003 - Control Module 014 - Defective - MIL ON it still lasts
    Is it possible to delete this error?
    Is the unit damaged?
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Check, if still not ok, srs unit is faulty ...
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
  6. The Following User Says Thank You to dragon100 For This Useful Post:
    jokir (16th January, 2021)
  7. #5
    reproteq's Avatar
    en algún lugar de España
    hi tested solution here
    post result pls
    tnks
  8. The Following User Says Thank You to reproteq For This Useful Post:
    jokir (18th January, 2021)
