which OS you have?
which OS you have?
Thank and rep given but i not receive the password freind
Envoyé de mon Infinix X680B en utilisant Tapatalk
EpicFail78 (20th January, 2021), Soufiane DP (18th January, 2021)
I do not know what password you talk about, I uploaded it for free for the benefit of everyone Of course, who knows how to work on it
DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etcDo not forget to press the button thanks and reputation
# Algerian #
MyTee (19th January, 2021)
dont need to make any action, only the right installation with the right rules to setup it
I think It will be little more complex.
We are going to suppose that since Winols1234 they didn't change the security of Winols (I remember Armadillo 4xx).
Then, It exists an Hardware fingerprint linked to the main aplication and also exist a reg file in some place in the register.
So the steps will be:
-First, look into register for armadillo registers (Using trial reset). To copy then to other SO.
-Second look for your hardware fingerprint (Using the same version of armadillo).
-Making a loader to emulate the hardware fingerpring in the new OS.
I can be wrong, If yes please, correct me
It is better to arrive 10 minutes early, than to be bored all the way.
Yo, thanks for this
//Works perfect, just use "Moved it" in the VMware Dialog.
https://mega.nz/file/uiwBBQTa#G3CSJ5...RILzCdm4YQnLe0
WINOLS 2.24 WIN7 32BITS
ECM TITANIUM WIN7 32BITS
https://mega.nz/file/2vxWTK7a#aj_eUz...FrC1AMnLBxwKKg
hakonholmgren (21st February, 2021), mecmack (27th February, 2021), okm (13th May, 2021)
I've tried running it but to no avail, I used the bat file in the C:\ directory to start it so the date would change to 2019, the reset bat file seems empty it just says echo nothing else. Tried copying the contents of the folder on the desktop but doesn't work, it still gives the registration notification and doesn't load any plugins
