Results 1 to 4 of 4
    Germany
    Default AUDI Q7 2007 3,0TDI BUG EDC16CP34 pin from dump please
    Hello i need the pin code from new and from old ecu. Because i want to swap ecu old one was flooded with water.
    Thank you in advance and KInd regards
    skywoker's Avatar
    May 2012
    ROMANIA
    ORI - 15933, Spare - 45980.
    Spare ecu has immo off inside eeprom.
  3. The Following User Says Thank You to skywoker For This Useful Post:
    mm04kk (17th January, 2021)
    Germany
    i tried to swap with vcds but i get error do you can make it for me virgin
    now i know the reason why the ecu was already openend
    the car dont start and i alwys get the error that the coding is wrong
    Germany
    Hello thank you very much problem is solved i have swapped the data from old to new eeprom now works fine
