Hi ,original instruments eeprom contents damaged , please will you give login info, thanks , regards
Do what you can with what you have .
login ecu - 20261
login dash - 05128 - odo: 216672 km
need help
now my goal is to buy xp-005
who will help?
ecufix (19th January, 2021)
Pin immo new 5128
05128 instruments is correct , cant login on ecu , even tried loading other dumps with known pin codes , my immo off file works as long as the instruments remain disconnected, any ideas, thanks regards
Thanks to Frikkie , car sorted out , supplied used instrument cluster was not compatible with the exact model of car, replaced with a suitable cluster ,programmed it all together and Bobs your aunt , car sorted.Thanks for all inputs,regards
