Results 1 to 5 of 5
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default FORD EDC17C10 GPT EEPROM READING PROBLEM
    i face a problem with an ecu from Ford Fiesta 2014 edc17c10 GPT ecu,
    i make full read for back up, and after i make an eeprom read for backup too.....
    if you see the two eeproms, from a full back up and from an eeprom reading only you can see many difference in dump......
    why ktag make and gives other dump if you make full reading and other dump if you read just eeprom?
    it is safe to write back the dump that starts with zeros?
    Thanks....
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    no one have see that before?
    I make one more full reading, no vin number in ktag......
    I think my eeprom corrupted...... Is that possible in reading procedure?
    Feb 2018
    this is virtual eep
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    I put the ecu back in to car, it starts (i didn't expect that to say the truth...)
    But the engine blower start too....
    As i quess ktag, corrupt the eeprom..... Weird....
    Feb 2018
    do you install new ecu? and you make a copy
