Results 1 to 15 of 23
    Mar 2019
    Scandinavia
    Question Volvo S80 2.4 CEM P2 read on bench
    I need to read Volvo CEM
    HW - PN 9494594
    9494997
    99W263
    Have to replace ECM Denso He2 and also need to read CEM to get immo info..
    I have the Volvo Sync tool software for Synchronization
    There should be possible to read the CEM by I/O terminal tool without desolder 28F400, but then I need the PIN code...
    I'm not sure which activation in I/O terminal I need to buy... May be Volvo P2 to be activated in Volvo simcard..
    Can anyone tell me what and how to do?
    I'm very pleased for EVERY answer
    learning by doing, learning by experience... please thx is I helped you
    brend's Avatar
    Oct 2015
    Same where
    Which one?
    Quote Originally Posted by Willinickersen View Post
  3. The Following User Says Thank You to brend For This Useful Post:
    Willinickersen (19th January, 2021)
    Mar 2019
    Scandinavia
    Volvo S60, S80, V70, XC90, XC70 Synchronization Utility 1.4
    brend's Avatar
    Oct 2015
    Same where
    It's not work.
    belgrade,serbia
    volvo.rar here you are pictures how to make synhro ,you have to desolder flash an read
  7. The Following User Says Thank You to vladanr For This Useful Post:
  8. #6
    Mar 2019
    Scandinavia
    Okay thank you for your reply.
    This does exactly the same as "Codecard.eu software does. And I/o terminal also should do.
    Which software do you prefer or suggest? And how to?
  9. #7
    belgrade,serbia
    post dumps and someone will make you
  10. The Following User Says Thank You to vladanr For This Useful Post:
  11. #8
    Mar 2019
    Scandinavia
    Quote Originally Posted by vladanr View Post
    Okay, I understand you don't have read my thread.. I will do when I have sort out how to...
    Very strange that the software describes exactly the same as your software..?
  12. #9
    brend's Avatar
    Oct 2015
    Same where
    It's Tango sw, but this work only if tool is genuine.
  13. The Following 2 Users Say Thank You to brend For This Useful Post:
    rafal (19th January, 2021), Willinickersen (12th March, 2021)
  14. #10
    Mar 2019
    Scandinavia
    Hi and sorry for long time to upload files...
    Have read eeprom from ECM and flash from CEM. Tried to synchronize, got message that flash needs to be fixed and did so with the Volvo 1.4 sync tool. Then I synchronized. No fault when read OBD by volvo vida, but cannot turn the engine /starter motor. I belive there's other problems.
    But if you are able to check the files, then I can write the new files back to CEM.
    Have smok jtag for CEM
    Looking forward to your reply
  15. #11
    MartiLer's Avatar
    Dec 2016
    where are the dumps?
  16. The Following User Says Thank You to MartiLer For This Useful Post:
    Willinickersen (4th April, 2021)
  17. #12
    Mar 2019
    Scandinavia
    Sorry, attached now
  18. #13
    MartiLer's Avatar
    Dec 2016
    do you want to replace the ECM denso? making only sync is not enough.
  19. The Following User Says Thank You to MartiLer For This Useful Post:
  20. #14
    Mar 2019
    Scandinavia
    Quote Originally Posted by MartiLer View Post
    If there's nothing wrong with the sync or file, there's no need to replace.... There was something wrong with CEM file and the software repair it before sync
  21. #15
    Aivis3's Avatar
    Sep 2016
    Latvia
    HW - PN 9494594
    9494997
    99W263
    For Volvo Old CEM (Gray) you need a VOLVO SIM (For I/O Terminal)
    But you need to patch file before! (Need replace PIN with FF FF FF FF FF FF), then you can Read/Write CEM via OBD with I/O Terminal tool.
    You need to read CEM before anyway! Can read for example with Smok, USB NT programmer (via BDM) or chip desoldering.
    If helped - "Thanks" and "Reputation" please
  22. The Following User Says Thank You to Aivis3 For This Useful Post:
    Willinickersen (9th April, 2021)
