I have make 2 key
Nbr 3 and 1.
Not working
I have put emulator in place of elv.
Same result.
Envoyé de mon LYA-L29 en utilisant Tapatalk
Check, whether the ezs detect´s key insert. This you can do by diagnostic. Sometimes there is problem with microswitch. Maybe ezs was opened and the little copper lever falled out. And I had a vito ezs, there was no infrared activity at all, because hardware damage. I replaced the whole ezs and cloned data from old one.
Greets MR...
I can confirm, had also one w639 key ok, dumps ok, microswitch ok, steering lock ok so i replaced ezs and all ok, car started.
Seems like this ezs suffers from hardware damage, didnt have time yet to take a closer look at the hardware to find out where the fault in ezs hardware is.
Poslano sa mog SM-G975F koristeći Tapatalk
besides taking out from another EIS the "inserted in" microswith avaliable somewhere?
didi_du_93000 (22nd January, 2021), exxl (22nd January, 2021)
Weasel3 (23rd January, 2021)
Problem solved.
Switch modul defect.
I have swap from another eis (from w203) and all work well now.
Thanks for help
