i think if no manual procedure then remote intergraded
https://www.car-keys-online.com/genu...2012-2016.html
rob h (22nd January, 2021), super jumbe (23rd January, 2021)
There i aftermarket alarm installed.
Defa system.
That might cut off canbus.
This program with the key
Truecode or what tool are you using.
as Newone told you, you need original remote with integrated chip on the PCB and remote will work stright away after key program
I read that on some early models around 2014 is possible to add aftermarket remote manualy but I never had succes
Obdstar.
The owners remote, does not give any radiosignal.
I only tried adding a fsk 2012 up Ford remote.
I Will order, a oem key
Your not trying to use cheap chinese fobs are you Rob . Customer prob bought crap off ebay
I use to use the chinese autokey fobs intended for cars - worked well until they changed stock to cheap n nasty
Remote on those cheap fobs are separate thus won't program on these Transits.
Now OEM all the way with Fords
Solidarity with Ukraine
I use some Chinese remotes, on Fiesta and Focus, 2012 up.
These remote, i program in manualy.
When i google this BK2T-15K601-AB, i do find these keys with separate transponder.
So i will go with a recomended seller, and buy a oem.
US Fiesta has same basic remote system. Yesterday I programmed Rhk on 2019 Fiesta with dealer key (for dealer!) and remote did not program in at same time. I used 8 times on and off, wait for chime, press lock/unlock on each remote, on and off with key and done. Best success is when you start out, open and close door, lock with dash button, and then start key cycles. I have done transit big van with no chime, I think it was around 15 or2016. Kind of stumbled my way through it.
rob h (23rd January, 2021)
If think if transponder is id49 then remote programmes with on board pcb. 2014 below remote is manual procedure. Oem keys are the best on the later models.
Focus and Fiesta, yes.
This Transit, does not give any signes off entering programming mode.
No beep, no click, nothing.
I found to seperate discription,
And tried all, with without closed door, belt inserted, not inserted etc.
So either the aftermarket alarm installed, is messing up the can communication. Or Transit is different from others Fords.
I've met one time Transit Custom 2012 that i can use KD remote with separated TP.
But all others use remote integred in PCB. So for this model, only OEM key will work.
Remote programming in the same time than TP.
Thank you guys,
I have ordered a oem remote.
Soon as it arrives, i will program it.
And i will post the result. Pretty sure know, that it will work.
Greetings Robbert
About these Keys, with internal recharging batterys.
I looked die some replacement batreys.
I found the vl2032, to fit the older blue key.
What is inside these newer Keys?
And IT looks like the casing needs to be replaced.
Theses Keys are sealed.
