Hello, Try.
Pass in PM
Hello, Try.
Pass in PM
Sorry don’t work
NikoDiag (22nd January, 2021)
write this one................
need help
now my goal is to buy xp-005
who will help?
same pass - i did manually
need help
who will help?
ProTuner since 1999
the ecu bricked because of non correctly immo off file? are you kidding?
as Panathaole wrote - ecu can not be bricked with bad off file.............
anyway - i tried help - but as you wrote ( not work ) - apologize m8
need help
who will help?
brend (28th January, 2021), Panathaole (28th January, 2021)
Here is an example from bad immo off in ecu hw like yours... If you search i think you find many....
https://www.digital-kaos.co.uk/forum...-immo-off-file
After the bad file ecu reprogramming and work correctly.....
I have no intention of offending you, here we are more or less trying to help each other ....
it strikes me that a perhaps wrong file locked the ecu.....
is there maybe any other problem in writing the file?
You can wrote what you want on map location, also a wrong software mod, also a wrong checksum, there's no problem. If you mod wrong same file before map zone, booting could be impossible, then ecu don't be flashable.
first file sent had 1 bit mod on 791B. I have wrote this file many times, then ori back, no problem
second manual solution have 2 bit mod, one on 791B and another on 43D1 (some bit before map zone). Checksum corrected wrote with ioterminal on 2 ecu, both not respond anymore. Tried with smok, kess, ioterminal. No way
What do you think?
ProTuner since 1999
If you want at your own risk try this .... cks is corrected...
and try if you have galletto v54 to connect with your brick ecus....
gtronic (23rd December, 2023), kido resuri (22nd January, 2023), speedservice (1st September, 2023)
