    Default Astra J A17DTC dpf and egr off.
    Please help remove EGR and DPF from flash file read by obd with kess ecu delco e87 from a17dtc engine.
    Attached file, thanks alot!
    Astra J.rar
    Gita's Avatar
    dt.tuning.gita@*****.com
    here off
    check pm for pass
    Chiptuning Remapping, file service, stage 1
    Diesel All cars
    Manual Adblue dpf egr tested working solutions
    Car,Truck,Agriculture.... etc.
    GITA-Electronic Service
    Hello Gita, I have tried it and the car does not start?
    hello, can you help me ....
    thanks.
    Jul 2018
    write ori file back. if car starts i can help u with tested solution
    Feb 2021
    Norway
    Quote Originally Posted by luiscarlo View Post
    First of all, did the fan on radiator start when you was writing in the file?, some other things happend? or just not started after?
    If its just not started, try to go back to orginal file.
