Results 1 to 6 of 6
    Jun 2016
    EU
    Default OBDSTAR DP300 FIAT Ducato Key Programming Problem
    Hi Guys , i try make spare Remote key for Fiat Ducato 2015 , PIN Read OK , but after Precoding Frequency stop working , i try two options all same situation , maybe someone has same problem like Me ? Give any suggestions as you can .
    Mar 2018
    UK
    What key use?
    XH and KD and cheap chinese keys doesn't work on this van
    P&D's Avatar
    May 2010
    Quote Originally Posted by darox2005 View Post
    Did you use a Mareilli remote ?
    rob h's Avatar
    May 2011
    I have had a similar problem, with a Boxer.
    I could not get the remote to work, trying with xhorse and chinese marelli.
    Done a few, all others went fine.
    And reading eeprom by obd, 1 time, a Jumper. ( not readable with obdstar, and not with smok uhds)
    I took the bcm out, precoded keys using dump, and added these, using Obd port.
    So not all off these, are exact the same. Maybe a software update, in some.
    And these bcm, are very easy to take out.
  5. The Following 2 Users Say Thank You to rob h For This Useful Post:
    darox2005 (23rd January, 2021), Weasel3 (23rd January, 2021)
  6. #5
    Mar 2018
    UK
    Truecode + TMpro2 + renewed original key
    works fine every time
  7. The Following User Says Thank You to Manta1600 For This Useful Post:
  8. #6
    Jun 2016
    EU
    Thanks guys for reply , a use marelli key board one original with new pcf7946 also one new from china , but very strange before programming and precoding with booth key frequency work fine , i remove bcm Monday and read eeprom , then try one more with OBD like suggestion '' rob h ''
    Thanks to All
    I report when i fix problem
