Results 1 to 12 of 12
Hybrid View
    May 2011
    Default Renolink Clio 3 key
    Hello friends im trying to program my wife clio 3 key with renolink 1.87.
    Ive clicked in read pin (all is ok)
    Ive clicked in connect (all is ok)
    The problem is i cant click in test presence (its a blank key)
    The only option i can click is start learning and when i click it only validate appears to click and should be able to click in learn key/card...
    What is wrong? Someone here managed to program clio 3?
    Thanks all
    drupal's Avatar
    Jun 2020
    Attachment 779144
    Hi,extream87 flow these steps and watch this video
    https://www.youtube.com/watch?v=WZj7...BE%D1%84%D1%84
    May 2011
    Done that but i get an error and the program disconnect...
    Aug 2019
    Bucharest Romania
    Quote Originally Posted by extream87 View Post
    1. Ive clicked in read pin (all is ok)
    2. Ive clicked in connect (all is ok)
    OK.
    This step isn't necessary.
    3. Click "Start Learning"
    4. Insert key nr. 1, turn the switch on and wait for 5-6 s ; turn switch off and remove key nr. 1
    5. Insert key nr. 2, turn the switch on and wait for 5-6 s ; turn switch off and remove key nr. 2
    6. Click "Validate"
    7. Click "Disconnect".
    READY!!!
    Feb 2021
    Default Renault Scenic (2013)
    Quote Originally Posted by andreia67 View Post
    OK.
    6. Click "Validate"
    READY!!!
    Hi all,
    I have one original key that came with the car, but the second one is damaged. I bought a blank key card and want to program it.
    Looking at the steps above I have a question ?
    Step 4. - Can I only use blank key card not mine original.
    and before Step 6. do we need to press Learn Key before pressing Validate.
    Your help is much appreciated.
    Aug 2019
    Bucharest Romania
    Quote Originally Posted by kalecg View Post
    Hi all,
    You must learn ALL the key you want to use. Used or new (blank) it doesn't matter. Blank key must have correct precode.
    IF after you insert key nr. 1 and switch on you have "Learn Key" button press it and look at the bottom of the window for the message "Key learnt OK". Remove key nr. 1 and do the same for all keys you want to learn.
    After you learnt ALL keys press "Validate" button.
    This procedure is the same for all UCH's. Some don't have "Learn key" button (for exemple UCH transv Siemens used before 2010 in Logan, Sandero, Symbol, Twingo ph2, old Duster) and some (especially newer ones) have "Learn key" button.
    May 2011
    Yes for me doesnt show learn key. I read pin, connect and when i click start learning i get 7f3122 conditions not set
    Other times when i click start learning only validate appears but the key id shown is the same for the 2 keys so i assume something is not good.
    Ive used Mr. Rorri tool to check if the pin is ok and renolink pin and Mr. Rorry tool is the same so i assume the pin is correct
    Aug 2019
    Bucharest Romania
    7f3122 conditions not set = defective key. It happens with bad quality chinese keys.
  9. The Following User Says Thank You to andreia67 For This Useful Post:
    godfathertre (16th February, 2021)
  10. #9
    Aug 2023
    Hello.
    I have a big problem with my Espace IV Bj. 2007
    I used Renolink and I can't add a new key.
    When I add a key, Renolink says:
    7f8022 Conditions not specified or sequence error and now I have tested the two cards that I have with all transponders and the transponders from Aliexpress are all on 315 MHZ, I now use the original transponder from the car I get the message 433 MHz.
    But I can on RenoLink, although I can click on Read Pin then it shows me the pin that is stored in the UCH and then I click connect and click on Learn Kart and it still shows me and just the same number no matter what I do make.
    Even if I put another card with another transponder in, I still get the number that is stored in the UCH and unfortunately nothing else happens
  11. #10
    Sep 2020
    Le havre
    Good evening, try to redo the procedure with the driver's door open.
  12. #11
    Aug 2023
    Quote Originally Posted by Christiano76 View Post
    Guten Abend, versuchen Sie, den Vorgang bei geöffneter Fahrertür zu wiederholen.
    hello, the driver's door is open and everything else like lights etc. is switched off.
  13. #12
    Sep 2020
    Le havre
    Good evening, the door open is to have a current consumer to "wake up" the UCH.
    Test with the warnings on.
