The problem with my BEEprog programmer is that it successfully reads every chip in the ZIF socket but can't program or delete any chips.I tried several different chips to delete or program but without success!It can't even delete and program serial eeprome 24C series!
Everything works properly on the ISP connector!
When I did the self test for ZIF I got the following:
WELCOME in standard selftest procedure for programmer BeeProg
L0531:
L0532: 22.01.2021 23:39:26 Pg4uw, 2.67c/03.2010 selftest
L0533: Programmer: BeeProg
L0534: Loop no.: 1 Elapsed time: 0:00:00
L0535:
L0536: Socket isn't empty! Affected pins:
L0537: 25/1
L0538:
L0539:
L0540: Socket isn't empty! Affected pins:
L0541: 25/1
L0542:
L0543:
L0544: Communication test ............ OK 0:00:00.1
L0545: RAM test ...................... OK 0:00:00.8
L0546: EEPROM test ................... OK 0:00:00.4
L0547: Supplies and DAC test ......... OK 0:00:00.2
L0548: Pindriver (TTL) test .......... ERROR: #0303H.
L0549:
L0550:
L0551: Programmer s/n: 192-01618, BV: 0001H, rPCB: 04H, mPCB: 01H
L0552: Identification (X-Y-Z-R-IEC-D-SW): 1-25-0-0-0-13-2.67c/03.2010
Does anyone have a solution to this problem?
