Tried doing this before pulling with x-tool would not do it at all. Any ideas?? Does the 24lc32ai hold all the info i need to swap cluster??
Hey guys I have a customer with a 2008 Audi TT has dead cluster. Customer purchased used cluster. This dash has 24lc32AI eeprom as well as a micronas cdc3217g cpu. Can someone tell me where all relevant data related to vin,immo and mileage is stored?? Also can Can anyone tell me the contents of the 24lc32ai? It seems as its just part number of cluster nothing else.
I dont have FVDI. I have ODIS with geko id however I have error as odis recognize this dash as used will not let me adapt. Any other solution?? can I write data from original 24lc32ai to used cluster to match to immobilizer??
No eeprom its encrypted with key in CPU
Keep in mind, English is not my native language.
the easiest way to change that dash is to transfer immodata. but you need to read micronas too.
Read and post micronas Cluster dead is in micronas not in eprom
Best tool to read micronas on bench??
Xprog programmer. Through obd i think its impossible
Don’t have xprog will carprog do it??
carprog yes, but only via obd
no, carprog not support micronas
Maybe try repair the old cluster.
or here you solution
https://www.digital-kaos.co.uk/forum...-read-Micronas
I dont think its possible But I will post picture for failure. Its a 20pin chip Looks like texas instruments VPSA132A 75T.
