Page 1 of 3 123 LastLast
Results 1 to 15 of 36
    super jumbe's Avatar
    Livingstone
    Default Nissan Juke 2012 petrol Engine Won't Turn Over and Won't Start after key programming
    I have used truecode with glovebox pincode.
    Car came to garage for spare key after battery was dead all went good after 6 days customer said the old key stopped working, the new key was working good, when I went to programme old key it says pin not accepted, now both keys won't start car, is there any solution? Is there any way if I remove BSI and make key, the other issue I have noticed the fault code will not be erased, any help very much appreciated thanks.
    Livingstone
    Thia was the fault codes.
    lion0304's Avatar
    Oct 2014
    Juke i've did alway 4 digits pincode. Even model 2015.
  4. The Following User Says Thank You to lion0304 For This Useful Post:
    super jumbe (24th January, 2021)
    Jun 2013
    Ignition key I presume?
    Yes, it is in the list of Tang.
    2010 and 2011
    Two different types of eeprom.
    Maybe one is for regular and the other for prox. But I am not sure.
  6. The Following User Says Thank You to Weasel3 For This Useful Post:
    rob h's Avatar
    May 2011
    Do you have a better picture, with the dtc on it?
  8. The Following User Says Thank You to rob h For This Useful Post:
  9. #6
    Mar 2018
    UK
    Quote Originally Posted by lion0304 View Post
    Yesterday I've done Juke 2017 AKL with 4 digit pin code with smart key
    as you told, all Juke's that I had was 4 digit code
    Maybe exist juke with Micra immo that need glovebox code
    on Micra I had problem after flat battery the car forgot the original key I reprogrammed the key and the customer sell the car on 1 hour driving from me
    after 1 week he call me that the car lost the key again, then I went there and I programmed new and reprogrammed the original one for free
    After 1 month the customer told me that the car again can't recognise the keys and I told him that I don't wan't to see any more this car
  10. The Following User Says Thank You to Manta1600 For This Useful Post:
  11. #7
    Dec 2010
    Nottingham
    most are four digit but there is also some that require glovebox code converting , plenty have seen these though i havnt and all ive done have been 4 digit.
  12. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  13. #8
    Livingstone
    I used GLOVEBOX 12 digit label number then gave me the pincode when I last used to programme new spare key.
    Glove box sticker label number: A372AF1703E9
    Gave me this code to programme: 1430DAD556A2
    I used truecode was asking for 12 digit pincode, look I have done with truecode lots of Nissan this is the one giving me the issue, look whats the solution?
  14. #9
    Mar 2018
    UK
    Quote Originally Posted by super jumbe View Post
    Did you press the clutch?
    is the car is on P if is automatic?
    What happens when you switch ignition ON is the lights comming on the dash?
    Post better picture on the faults
  15. The Following User Says Thank You to Manta1600 For This Useful Post:
  16. #10
    lion0304's Avatar
    Oct 2014
    I've never met yet key lost in memory. But i repair many NATS5 immobox around ignition lock that just ignore the key.
    Maybe in Micra, wirring problem or BCM? I don't think memory can lose easy by that way.
    Also SSangyong immobox many not recognise keys, you can recode but problem come back again. I alway repair and say goodbye.
  17. The Following 3 Users Say Thank You to lion0304 For This Useful Post:
    p1et (24th January, 2021), super jumbe (24th January, 2021), Weasel3 (24th January, 2021)
  18. #11
    I recently made a akl to this vehicle, using Zed full, the problem was that I could not make a second key that the customer wanted no matter what I tried.
    For your problem , try to do programming using another device, maybe it will work
  19. The Following User Says Thank You to key4man For This Useful Post:
  20. #12
    Livingstone
    Quote Originally Posted by key4man View Post
    I could understand as said but other tools asking for 4 digit pin how can I get 4 digit pin when this car has glovebox label only do I have to read BSI dump for this thanks.
  21. #13
    I'm not sure about the other devices, but regarding the zed full it bypasses the code, I suggest you try to disconnect the cables of the battery Connect them together to drain the power from the vehicle, reconnect and see what happens
  22. The Following User Says Thank You to key4man For This Useful Post:
  23. #14
    Livingstone
    I did discnnected battery over night no joy look at the pictures programming with truecode.
  24. The Following User Says Thank You to super jumbe For This Useful Post:
    Manta1600 (24th January, 2021)
  25. #15
    Livingstone
    Has any one made a key from BSI Dump on Juke 2012 with tango?
