Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Jan 2021
    Default Mk4 ARL 1.9 - More power
    Hello to everyone.
    can someone add more power, boost on this file ? edc15 ecu Mk4 - 2003 year - 110 KW
    thanks in advance
    Klaudas1331's Avatar
    Dec 2020
    Lithuania, Kaunas
    File is already modified
    If my post was helpful, don't forget to press thanks!
    Jan 2021
    Quote Originally Posted by Klaudas1331 View Post
    Yeah, but looking for more power and boost if possible also on low rpms it looks like stock,
    Tried new ori maf, cleaned turbo, new n75 etc but no success,
    Seems something wrong inside map file
    Dec 2020
    Lithuania, Kaunas
    Try this then, password will be sent to pm
  5. The Following User Says Thank You to Klaudas1331 For This Useful Post:
    skzmaps (24th January, 2021)
    May 2017
    seams pretty much like ebay cd tuning .
    I will upload you another tune in ~15min
    Jan 2021
    Seems same, or not big diff, cant see any good difference
    Jan 2021
    Quote Originally Posted by Lambda1 View Post
    Okay,
    Waiting
    Thanks!
    May 2017
    here you go
  10. The Following User Says Thank You to Lambda1 For This Useful Post:
  11. #9
    Jan 2021
    here you go
    Thanks! Does it have more power than the one i have uploded ?
  12. #10
    May 2017
    DO CHKS and flash it...test it. Maybe its blown, maybe its good, maybe its waste, maybe you will be god.
    You will see!
  13. The Following User Says Thank You to Lambda1 For This Useful Post:
  14. #11
    Jan 2021
    Ok, Thanks! will report within 15 minutes.
  15. #12
    Jan 2021
    You will see!
    just tested it,
    results are better, but not like arls of my friends :A
    new engine rebuild, new maf from germany original, new boost sensor, turbo repaired with original parts and can't see when they are faster haha!
  16. #13
    May 2017
    Do a log... values it should done I wrote to you in pn before...
  17. The Following User Says Thank You to Lambda1 For This Useful Post:
  18. #14
    Jan 2021
    What should i log? What u need to know ?
    Can a stage 2 file from ur profesionality will fix it?
  19. #15
    Apr 2011
    As I understood, you have problem with low power at lower rpms?
    - measure vacuum at wastegate, should be above 22-23 in-hg at idle. If not, check for vacuum leaks until you get to this value. When you measure, press brake pedal, it should drop, and get to 22-23 again fast. If it's building slow, again - vacuum leak or vacuum pump.
    - block EGR valve with metal plate, and also block vacuum hose to it with some screw or metal ball
  20. The Following User Says Thank You to Tawe For This Useful Post:
