That ecu works well in bootmode, if it fails then flash/eeprom is damaged or mpps/bench config is bad.
Hello everyone,
I had a problem on my stilo when writing map on ecu with mpps error came up.
I tried recovery trough boot mode but still nothing it came at 16 17% and another error came up.
Then i tried to do immo off on another ecu original was 0281011553 and other 0281011552.
The car started and had error such ABS ESP Check engine it was Christmas morning on tacho then i tried to put my software on that ecu and everything works fine but there is a problem in a communication with tacho there is no fuel consumption instant or average or fuel range whatsoever but it was when it was original software from 552 ecu with abs and esp lights on.
The flash chip was damaged i ordered ecu and removed immo from flash and eeprom and now is fine. And now i need to make a good tune for it.
Good, sometimes it can be too any capacitor, resistance or MPPS did full write instead of maps.
Jet Turbo Diesel 8v stage1+ | Yt Playlist
You dont to buy new ecu
Just reflash by boot mode or with a programer
You still have the original 95p08 eprom so dont need immo off
No matter what ecu number you buy as long is edc15c7 just flash a file with your number you have plenty on forum here
I tried boot mode but no success error at 17%
