problem isn't in ECU dump.
Problem is in DTC 008875 - fuel pressure on common rail too high
Engine won't start with this DTC - check FUEL PRESSURE sensor and FUEL PRESSURE regulator.
That is it...
That is it...
If my solution helped You - do not forget to THANKS !!!
vladar1 (26th January, 2021)
Command RZ005 via Renault Clip on Dacia Docker, K9K resets DTC008866, DTC008875. Resetting the injection pump and ramp adaptations did not produce any results. Most likely, this situation appears after the pressure in the rail goes off scale, due to a valve wedge in the injection pump or ether at startup.
check live data rail pressure
