Results 1 to 9 of 9
    Jan 2019
    Newfoundland canada
    Default 2009 SATURN ASTRA imobilizer pin code
    can anyone please help with 4 digit imoblizer pin code , tryin to program spare key for 2009 saturn astra vin W08AT271295029398
    Aug 2020
    Quote Originally Posted by glenchafe View Post
    NO NEED FOR MULTIPLE THREADS. IF SOMEBODY CAN HELP YOU, THEY WILL WHEN THEY SEE YOUR POST. THIS IS NOT AN ON DEMAND SERVICE.
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
    Jan 2019
    Newfoundland canada
    some times i post in imobilizer i get answer and sometimes in locksmith but i have tried both separatly at times and get results differently , and i do not belive this is a on demand service and appreciate any help any one gives good or bad . thanks for your input though
    p1et's Avatar
    Oct 2013
    Most likely noone will provide you PIN from VIN. There are many ways of obtaining PIN code from this car.
  5. The Following User Says Thank You to p1et For This Useful Post:
    glenchafe (29th January, 2021)
    Jan 2019
    Newfoundland canada
    i have autel im608 i cant see how to get pin from this , i also suscribe to gm and have sps programing but no option to do relearn key . every gm product i have had yet i can relearn theft through sps but for some reason this saturn does not have option, the autel pulls pin codes for many makes but not this particular saturn, it will however relear it or do all keys lost like the problem i have but requires pin. i have connections at dealer b ut they do not know what i am talking about when i ask for 4 digit pin , its a new key from dealer but they no nothing of 4 digit pin. evry imobilizer tool i have requires it for this car , the dealer provided me with a 4 digit pin for radio but thats not it and they keep saying the 4 digit pin is located inside the key when you take it apart , but that i know makes no sense so i am stumped.
    p1et's Avatar
    Oct 2013
    Glad to know not only polish dealerships are piece of junk
    PIN is stored in couple of modules in this car. If your 2009 is equivalent to Astra H, (because from 2009 started Astra J) you can for ex. remove REC module (left side of trunk) and read eeprom from it, then I can help with calculating PIN code.
  8. The Following User Says Thank You to p1et For This Useful Post:
    Weasel3 (29th January, 2021)
  9. #7
    Jun 2013
    That would be the same as a Vauxhall or Opel Astra H.
    It might help to find out exactly which engine ECU version you have.
    Maybe locate it. And take a picture if not sure.
    And also read out part number by OBD. Read out the info of ECU, to get what you are after.
    Its better to find out which one, before testing all options.
    To avoid any type of waiting.
    Either by the long time of reading every option available.
    And also when trying wrong options.
    Can get kicked out, and given waiting time.
    Before allowed back to do more programming.
  10. The Following User Says Thank You to Weasel3 For This Useful Post:
  11. #8
    Jan 2019
    Newfoundland canada
    i will try both suggestions and check back thanks for all help
  12. #9
    Jan 2019
    Newfoundland canada
    thanks for all help , turns out the radio 4 digit code was the same code i needed for key , the dealership gave it to me first but i wrote it down wrong , didnt question it because didnt think it would be same code has radio punched it in and all worked . thanks again for all help
