Results 1 to 11 of 11
    Default Land rover range rover 28C16 problem
    Pleas help, im need 177 000 km tacho say km teller eror
    try this bud
    sory doesn't work this dysplai show km teller error
    kokino
    Unhappy
    Be those too second place
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by kokino View Post
    kokino
    Mate ... you must power up the dash in the vehicle ... before you put the EEporm back in .... This resets the ECU ...to zero ... Switch of ... remove dash .. then replace eeprom .... Power up in car ... Job done .....
    Talking
    OK....dash out....eeprom out.....programing......dash in car on key.....proc reset to zero....dash out ...eeprom put back in dash....dash put in car job done yes thx .
    ok koki
    Default oke
    this is procedure ok
    thanks for this
    Top Poster pinky1970's Avatar
    Tenerife
    what programer are you using to reprogram the 28c16
    Newbie BIDUL84's Avatar
    you start contact in car without dash
    5 min
    and programing your 24c16
    and remove the dash
    up the 24c16 in dash
    up all in the car and start
    is good
    regards stephane
    dimitar's Avatar
    Default hi
    Quote Originally Posted by BIDUL84 View Post
    5 min
    and remove the dash
    is good
    regards stephane
    I preffer the PremierD explanation more, your steps are kind of mixed yea?
