solution would be to use better tool
Weasel3 (27th January, 2021)
what tool ??
any other tool that can gain security access, if you want to be sure and safe some of ori tools would do job 100% like enigma, dp4, smok or abrites.
Need flash repair. Good and original tools can do this.
Изпратено от моят SM-N950F с помощта на Tapatalk
SMOK, J-TAG Smok, MagPRO, FLEX, VVDI, VVDI MB, VVDI 2, VVDI Prog, DP 4, K-TAG, KESS, ELNEC...
i try make corection xtool 2 or dash tool 2. must have erased security ascesso
For some 8P-dashes there exist sgo flash files. this should repair damaged flash also. You would need VCP or ODIS to get live back into dash. Otherwise you will have to read/write flash with xprog. But this is nothing for beginners. Most modern dash tools can repair this by obd also. This are your options... :-)
For first option post part number of dash.
Greets MR...
need repair flash yes. who made? i need heelp
part number of dash???
Greets MR...
i have xprog original,vvdi prog, xtool 2,
8P0 920 932 A VDO
You could flash this sgo to dash and it should be alive. You can flash it with ODIS-E (VAS5054 or newer), VCP or maybe VVDI2.
Good luck.
Greets MR...
Or maybe you have launch x431 with online programming. With it I successfully flashed many modules on VW and Audi, but dashboard never tested, but should work.
Greets MR...
this dump is flash or epron 24c32?. i need dump 24c32. yes i have x431 V
What I sent you is vw update file. You dont need eeprom. You need flash file. Better read your flash (micronas), let it repair and write it back. Easier is to update the cluster, but for this you need vw flash tool. If your x431V has online programming, just update the dash with it...
Greets MR...
