Results 1 to 15 of 16
    Europa
    Default help read mcu 2j74y
    hi
    I need help with upa and motorola 68hc908az60
    2j74y
    I plug in as page 16 of the upa help but I can not read.
    device not responds
    The UPA is fine.
    the mcu is fine.
    I am warm but does not respond to the mcu.
    someone knows how to read the mcu?
    greetings
    near Strzyzow
    Are You sure, that MCU is fine?
    UPA read it well.
    Is this from EZS?
    Maybe secured MCU?
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by jjas40 View Post
    hi
    2j74y
    device not responds
    The UPA is fine.
    the mcu is fine.
    greetings
    Never had any success reading with UPA ... ETL's the one you want mate .....To do with security bits .....
    Europa
    hi
    yes upa read good with other devices.
    the mcu is uch renault espace year 2001.
    I am not sure of the proper functioning of the mcu.
    uch heat the work.
    uch with the cold does not work.
    I give you heat the mcu and the device does not detect upa
    not if I do something wrong.
    as I read the mcu?
    greetings
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by szogun0 View Post
    UPA read it well.
    Is this from EZS?
    Maybe secured MCU?
    Yes mate ... 908az60 ... is secured .......
    Europa
    hi
    What solutions can I have?
    bits of security.
    What do you mean?
    I have checked the box.
    greetings
    Jose19's Avatar
    From the HELL
    hi
    bits of security.
    What do you mean?
    greetings
    If you use UPA, you need to know security bytes.
    With ETL is the best way
    Hungary, Mosonmagyar?v
    hi
    2j74y
    device not responds
    The UPA is fine.
    the mcu is fine.
    greetings
    Hi!
    Lift or cut reset,irq and pta0 pin.And try this helps possibly.
    $00-$00-$00-$00-$00-$00-$00-$00=MC68HC908AZ60(Default)
    $10-$0C-$10-$09-$10-$06-$10-$03=MC68HC908AZ60(2J74Y)
    $11-$11-$11-$11-$11-$11-$11-$11=MC68HC908AZ60(2J74Y)
    $22-$22-$22-$22-$22-$22-$22-$22=MC68HC908AZ60(2J74Y)
    $46-$FF-$8E-$00-$49-$E2-$8E-$00=MC68HC908AZ60(2J74Y)
    $49-$50-$59-$BB-$0D-$02-$08-$82=MC68HC908AZ60(2J74Y)
    $86-$C9-$86-$C9-$86-$C9-$86-$C9=MC68HC908AZ60(2J74Y)
    $AA-$08-$AA-$08-$A9-$94-$AA-$08=MC68HC908AZ60(2J74Y)
    $BC-$B8-$C8-$06-$C8-$06-$C8-$06=MC68HC908AZ60(2J74Y)
    $E5-$78-$EE-$F9-$EE-$F9-$EE-$F9=MC68HC908AZ60(2J74Y)
    $E5-$DD-$E4-$0A-$67-$2B-$E5-$DD=MC68HC908AZ60(2J74Y)
    $E5-$E3-$E4-$10-$67-$2B-$E5-$E3=MC68HC908AZ60(2J74Y)
    $F8-$F2-$F9-$F3-$F9-$F5-$F9-$F7=MC68HC908AZ60(2J74Y)
    $F9-$F1-$F9-$F4-$F9-$F7-$F9-$FA=MC68HC908AZ60(2J74Y)
    $FF-$FF-$FF-$FF-$FF-$FF-$FF-$FF=MC68HC908AZ60A(Default)
  9. The Following User Says Thank You to kareszka For This Useful Post:
    Dalplex (24th February, 2018)
  10. #9
    Europa
    hi
    equal. the MCU does not respond
    ETL?
    I do not know
    anyone know tell me that is ETL.
    I need to read the mcu to copy it to another uch
    greetings and thanks
  11. #10
    Top Poster + jimthejock's Avatar
    Scotland
    Default MCU 2J74Y
    go and look on here www.etlweb.com/
  12. #11
    hi
    ETL?
    I do not know
    Hello
    Lift/Cut IRQ, PTA0, and reset pins, solder the wires from the programmer direct to MCU pins
    select 68hc908az60 from the device list
    Click auto baud button, if this action fail you have connections problem but in some chips
    auto baud may not work, in this case you have to set baud rate manual
    Set Baud rate manual (correct baud rate your can calculate according device datasheet - monitor section)
    if no success increase/decrease baud rate with 10 or more
  13. #12
    Hampshire
    Sorry to butin but im having problem locating an adapter to read fiat brava immo chip ,which is MC68HC908AZ32 mask J66D ,any idea guys about etl and compatibility with the above ic?,where can get an adapter for this 64 leg ic.
    im usning UPA ,but its not in its list,plus dont have the adapter to go with my soft,thanx in advance.
  14. #13
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by nazz2 View Post
    Sorry to butin but im having problem locating an adapter to read fiat brava im*o chip ,which is MC68HC908AZ32 mask J66D ,any idea guys about etl and compatibility with the above ic?,where can get an adapter for this 64 leg ic.
    It reads inncircut with UPA mate ..... you don't need an adapter ....
  15. #14
    Hampshire
    Thanx premier d ,would the digramm be in the upa help fine?im going to check again i dont know how i missed it,thnx
  16. #15
    Moderator
    PremierD's Avatar
    Jun 2009
    http://www.digital-kaos.co.uk/forums...53/index2.html
    The Rar file shows you it connected ... No need to lift any pins ... Press auto baud .. Then read mate ....And yes there in the help file ...
